Computer restart’s when playing games.
Is it the gpu or the psu?
この質問は役に立ちましたか?
Start with the simple easy stuff. It used to work fine now it doesn't. If your case has filters, clean them. Check that all fans are working and that they are not full of lint, dust, fur or what-have-you This includes those on you CPU and GPU in particular. Is anything blocking your airflow into or out? Have you moved it so that now there's obstruction that didn't used to exist, Wall? Carpet?(Shudder), other equipment? Install speedfan (its free) now you can see the temps, fan speeds and figure out what is overheating as well as configure your cooling or use whatever software you prefer to achieve that. Once you identify the culprit, assuming a good cleaning and good airflow didn't work it will be time to consider hardware issues beyond dead fans. Replacement of thermal paste might help if it is more than a year old... otherwise the diagnostic. Information from speedfan should make further action pretty. Clear. Speedfan https://www.almico.com/sfdownload.php good luck. Do remember to power off and unplug it while fooling about inside, for your safety and your computer's.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 726
10 件のコメント
What GPU are you using and what games are you playing?
guardian10 さんによる
I use an rtx2060 like i can play league of legends no problem, but i tried hearts of iron 4 , 12 minutes , metro 2033, red dead redemption 2( which it used to run without any problems)
Rares-Adrian Vîlceanu さんによる
@Rares-Adrian Vîlceanu The GPU should be good enough for those games.
guardian10 さんによる
What is your system's temp, and what CPU are you using?
Jacob Mehnert さんによる
What wattage does your PSU supply? Also, what CPU are you using?
shingle さんによる
5件以上のコメントを表示
