メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Retrieving documents from another computer
I have a custom-built gaming desktop computer that beeps continuously when I turn it on so now I have a newer gaming computer but would like to retrieve files from the first computer. How do I do this if the other one doesn't turn on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Julie Lafountain the easiest would be to remove the storage HDD from computer one and place it in an external USB case. Then you can take it and connect it to computer #2 via USB cable and access the files. We would need to know what HDD is in computer #1 to suggest which external case since it has to match the Hard drive connector. Most likely something like this would work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Julie Lafountain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 68
