メインコンテンツにスキップ
Dell XPS 15 9560は2017年に発売された軽量で高性能なノートパソコンで、4K解像度の薄型ベゼル15.6インチスクリーンと第7世代インテルCore i3-7100Hを搭載している。
How to permanently disable the 1050
I have this xps 9560 with a fried GTX 1050 and i want to use the pc and just disable the 1050 because right when windows detects the card it BSODs. Any help on permanently disabling it is helpful.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi @thattechman,
Don't know as the manual is not explicit but try getting into BIOS > Device Information > Video Controller and check if there is an option there to disable the Nvidia GTX GPU and use the integrated Intel GPU as the primary (and only) display adapter.
このアンサーは役に立ちましたか?
スコア 1
14 件のコメント:
Hello! thank you for replying. There is no option for device information in the BIOS. These are the options
General
System Config
Video
Security
Secure Boot
Intel Software Guard Extensions
Performance
Power Management
POST Behavior
Manageability
Virtualization Support
Wireless
Maintenance
System Logs
SupportAssist System Resolution
さんによる
@thattechman
Did you look in System Configuration or Video to see what options are there regarding the graphics adapters?
さんによる
It will not go into windows for more than a few minutes before BSODing, when i did get to the graphic adapters it was fine until the gtx 1050 showed up and then almost instantly it bluescreened
さんによる
@thattechman
Try getting into BIOS on startup if possible i.e. don't go into Windows.
That's what I meant about looking at system configuation or video. If there are any settings in BIOS not in Windows
さんによる
All those settings i sent above are from the BIOS, not in windows.
In video all you can do is ctrl the brightness, and in system config it has as follows: SATA Operation, Drives, SMART Reporting, USB Config, Dell Type-C Dock Config, Thunderbolt Adapter Config, USB PowerShare, Audio, Keyboard Illumination, and Misc Devices
さんによる
9件以上のコメントを表示
コメントを追加
回答を追加する
John Dragonette さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 45
今までの合計 3,437
