メインコンテンツにスキップ
もしやり方を知っていればできていたことが沢山あります。このページではある特殊な修理をするには必要な特化スキルを一覧で表示しています。
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
さんによる
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
さんによる
コメントを追加
2件の回答
ベストアンサー
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Technique for Removing Bits
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
さんによる
コメントを追加
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
aaronmiller さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 35
今までの合計 1,795
