No sims on display
No sims is the display shown on screen.
Sims tray appears fine and not bent. Phone store tried several sims card and had the same display.
What else could it be?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Check the sim reader for any debris or some of the pins are not making contact with the sim card due to damage, bending , etc.
このアンサーは役に立ちましたか?
The sim holder is probably damaged. There is a contact in there that opens when a sim is inserted. If the contact doesn’t open it will not detect the sim.
You can check this as there is a hole in the top of the holder above the contact but you will need to be careful when removing the silver heat sink that none goes into the holder, this heat sink serves no purpose and does not need to be replaced. You will only need to remove the screen to check this contact.
Sim out
Sim in
このアンサーは役に立ちましたか?
Thank you! I now have to build up the courage to open this phone.
Is it possible to remove and replace the Sims reader?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 79
