TV remote control circuit contact problem
If I insert the battery in to lg TV remote control the IR emitter sends a signal, without press any button on the remote control, how can I solve this problem?
Hi @ayaya
Check if any buttons are stuck down.
If not you will have to open the remote and clean the motherboard using Isopropyl Alcohol 99%+ (available from electronics parts stores) as something is shorting out the tracks on the board that the buttons make contact with when pressed.
Here's a video that in principle shows what to do.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 81
