メインコンテンツにスキップ
ロジクールMX Master 2Sワイヤレスマウスの修理・分解情報です。2017年に発売され、モデル番号M-R0066、910-005131、910-005139、910-005839、または910-005965で識別されます。
11回答 すべてを表示
Sensor no longer picking up movement.
All other functions of the mouse work normally, it just will not pick up movement.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
1件のコメント
Ok this is weird - the same thing happened to me too, on the SAME DAY!!
さんによる
コメントを追加
2件の回答
ベストアンサー
This happened to me last week on the same day as you posted your question, spooky!
To fix it I found this repair guide, which suggests that the gesture button can get stuck if it gets pressed... wrong.
I used this teardown guide to open the mouse up with an iOpener to soften the sticker adhesive and a metal spudger to peel it up, then broad tweezers to prevent tearing or grease from my fingers, I followed Steps 1-2. Then the first part of Step 3 to remove the black screws. I tested the button and its mechanism. Both seems to actuate fine, so I reattached it without tightening fully to give it a little wiggle room.
Once I reassembled the mouse and used the iOpener to soften the adhesive and smooth it back down the the metal spudger, it worked as good as new, if a little more crinkly on the bottom, which is undetectable in normal operation.
このアンサーは役に立ちましたか?
スコア 16
9 件のコメント:
I had the same problem, following these steps I solved it. Thank you!
さんによる
works like charm
さんによる
It helped me a lot! I just untightened the screws of gesture button twice, in first time it was also helpful, but after one hour the problem started again, after the second untightening is it good. Thank you a lot! My wife has a gold standard "new" mouse after that fix :)
さんによる
Perfect, thank you so much... Even our shop told me my mouse was dead... And need to be changed.
With you tips, my mouse is now working as usual !!!
Thanks
さんによる
Jest letting people know that this solves the same issue for the original MX Master!
さんによる
4件以上のコメントを表示
コメントを追加
Well my friend this video might helpful for you.
https://www.youtube.com/watch?v=VbgN4Ywt...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brentleigh Ward さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 90
過去 30 日: 290
今までの合計 11,377
