My laptop yoga c740 is stadinly terng of I have change the thermal pes
My laptop yoga c740 is suddenly training of i have change the thermal pest but ist fixed so if any of you have answer I well be thankful
Hello this is Maxed Out IT
Explain what is going on it is hard to read your post
このアンサーは役に立ちましたか?
My laptop yoga c740 14 ml is suddenly training of i have change the thermal pest but ist fixed so if any of you have the answer I well be thankful
So is your laptop you need to change the thermal compound? or is it over heating
sorry I'm not understanding what you are saying
@maxedoutit Bro the pc is turning off suddenly this is my problem
Someone recommended Me To change the thermal i have changed but still have the same problem
Is it fully shutting down or is it going to sleep if it's fully powering it might be the battery if you saw any damage on your motherboard or battery if the battery has some damage then this might happen dos it do this while it is charging if not look at ware the motherboard and logic board for damage
Its going sleep after 10/20 minutes its working again @maxedoutit
Good afternoon from the down under,
If it is going to sleep and then turning on after 10-20 minutes, let's run through a few things
All of these steps are good to use on any electronics device that you are trying to repair.
Please note you have selected the wrong device for categorising this question which is okay. I'll put it under the correct one. It's just something for you to know
このアンサーは役に立ちましたか?
@np_f1_2021 i have try all this 😞
@honer can you please give me a list of the outcomes of all of this, especially the question where it says; Are there any underlying/previous issues?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 112
