メインコンテンツにスキップ
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931回答 すべてを表示
*M220VA* fully disabling the HDMI sleep timer?!
I use my "TV" as a monitor, and there's a sleep feature on the set that causes it to turn off after so long I do not use it as a TV (I did when we had cable, but since then that's been eliminated entirely). I checked under Timer and even selected "Off" on the timer but the TV still shuts down "to save energy". I still see "No signal. The power will be turned off."
This TV is a power sipper, so I don't need (or care!) about the "feature" -- in fact, I hate it because when the computer it's hooked up to sleeps it shuts down and I need to wake up the TV after turning the computer on.
Is there any way to disable this nonsense? Ideally it should behave with a partial "sleep" mode, but I know with a TV it's on or off. Vizio says no (of course, but who knows with them) but there has to be a way...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hello this is Maxed Out IT
Fallow this
To setup a sleep timer: Menu > System > Timers > Sleep Timer Use the Left/Right Navigation buttons on the remote to highlight the period of time after which you want the TV to go to sleep: 30, 60, 90, 120, or 180 minutes. If you don’t want the sleep timer to activate, change the setting to Off.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Tried that. It didn't help.
さんによる
ok now the next sleep timer
さんによる
To help save energy, your TV is set by default to turn off after 10 minutes without a
video or audio signal. This feature can be deactivated.
To set the Auto Power Off feature:
Menu > System > Timers > Auto Power Off > Of
さんによる
Did it work?
さんによる
@maxedoutit The M220VA is too old for that.
さんによる
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 778
