メインコンテンツにスキップ
The Dodge Challenger Concept was unveiled at the 2006 Detroit Motor Show and was a preview for the 4th generation Dodge Challenger that started its production in 2008. Many design cues of the Dodge Challenger Concept were adapted from the 1970 Dodge Challenger R/T.
Oil getting out above the coil
Why the oil is getting out above the coil box, and since i started to see the oil the startup sound is reduced.
Dodge challenger srt8 2012 ^manual^.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Coil box? Ignition coils?
On the hemi head, there is a seal around the coils that is supposed to keep the oil under the valve cover. When that fails, you get oil around the spark plug etc. - real mess.
The fix is to replace the gaskets around the valve cover including the ones for the spark plug tubes. Pretty sure your car has 16 of those. Depending on what is in the way of the valve covers it could be a relatively easy job.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dodge Challenger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 241
