Why my battery is too weak
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 522
3 件のコメント
My battery is so weak
Dore Mone さんによる
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
Md Azad さんによる
not charge up properly/long enough
antonio さんによる
