メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010年に発売されたMagic Trackpadの修理ガイドです。
The pointer only moves vertically.
To be more precise there's only a narrow vertical band of the trackpad responding. Touching outside of this, central, band has no effect on the pointer.
I tried connecting it to another MacBook but with the same result. I’ve also tried to remove batteries and replace them with new ones and also to completely disconnect it but nothing.
The same thing happened a month ago, that time changing batteries solved the problem.
Do you have any idea?
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The sensor plate has become damaged. Did you drop it or sit something on it that could have damaged it?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
No, indeed I left it on my desk for one week during the holidays and when I came back it wasn't working.
さんによる 共有
@nikdef - Other than trying a fresh set of batteries they just isn't anything that you can fix (the Magic Trackpad2 has a sealed in battery).
さんによる 共有
It's just weird that it is sensible only in that narrow band. Thank you anyway.
さんによる 共有
@nikdef - Maybe the battery failed and pressed against the panel from the back side damaging it. Time for a new one.
さんによる 共有
コメントを追加
回答を追加する
Nicola さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 385
