メインコンテンツにスキップ
Repair guides and troubleshooting for Acer Predator 17.3" laptops, a group of high-end gaming computers from Acer. These laptops features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
16回答 すべてを表示
Battery not taking a charge?
My acer predator laptop all of a sudden stopped charging, one night it was charging just fine and the next day it just stopped, it wasnt moved from its spot or dropped or damaged in anyway, just stopped charging
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Try taking out the battery and starting it
さんによる
Hi @ josh price,
What is the model number of the laptop as printed on the label on the bottom of the laptop?
Have you tried a different compatible charger to see if that worked in case the charger or charger cord is faulty?
さんによる
@jayeff im about to order a new charging cable, will update when it arrives
さんによる
コメントを追加
1 件の回答
ベストアンサー
I will suggest checking the charging cable first, if there is a charging light indicating on your laptop and still doesn't get charged then under the laptop you will find a small battery reset buttonhole, using any pin you can reset the battery. Hope this will solve the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
josh price さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 13
過去 30 日: 38
今までの合計 1,257
