メインコンテンツにスキップ
Repair service for JM-103 Jaundice meter Draeger Bilirubin
Does anyone know of a repair company for the Draeger JM-103 Jaundice Bilirubin meter?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@mrozem that really depends on where you are located. Most BioMed companies should repair those meters. I suggest that you contact Draeger first at +1 866-343-2273 and if you get no help there, focus on the BioMed groups. Something like this one and see what they tell you. You could also try and see if your local healthcare facility has a BioMed department and speak with them. They may have somebody local that could assist you with that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
But what if my BioMed department doesn't ask me yet?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
But maybe I called the wrong one... idk. Author, do you have any suggestions?
さんによる
I think so. I also called the wrong department at first, but then I found one in the Philippines. Honestly, it was so important for me because the healthcare here is not so good and I trust only Biomed. As a nurse student, I researched this theme a lot and must say that we are still so far from the level of healthcare in the USA. But I hope things will change soon...
さんによる
I think so. I also called the wrong department at first, but then I found one in the Philippines. Honestly, it was so important for me because the healthcare here is not so good and I trust only Biomed. As a nursing student, I researched this theme a lot, especially on this source https://samplius.com/free-essay-examples... and must say that we are still so far from the level of healthcare in the USA. But I hope things will change soon...
Maybe someone knows any other companies similar to Biomed? I want to have a choice...
さんによる
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 64
