Don’t turn on
does not turn on. I tried all combinations with the power button but the computer does not respond. when I get off the charger, then the charger heats up as usual, but the computer itself does not react
Try the SMC reset on the mac,
https://discussions.apple.com/docs/DOC36....
If you are comfortable with taking the back off unplug the battery and plug it back in. and try start it again with the charger plugged in.
if this doesn't work you can try plug it into the charger and start it without the battery plugged in.
このアンサーは役に立ちましたか?
unfortunately does not help
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 269
Have you spilled any liquid, dropped it, or any other damaging things lately?
Benjamin Dover さんによる
no, absolutely nothing like that...
Irakli Kvirkvelia さんによる
Have you tried replacing the battery?
guardian10 さんによる
I doubt it is the battery as it don’t power on with the brick and it is only 2 years old.@guardian10
haven't tried it yet@guardian10
1以上のコメントを表示
