Seems as though the problem is in the OS and not the keyboard.
What OS is installed, Win 7, 8.1, 10?
Is it always the same programs that open?
Have you checked that the programs can't be opened by keyboard shortcuts?
Either on the desktop (if the programs have icons there) or in the list of programs, right click on the program icon of a program that opens and click on Properties > select Shortcut tab and check that the "shortcut key" entry = none.
Asi como describís el problema puede que ser virus, algún keylogger , te recomendaría antes que nada correr un antivirus en modo a prueba de fallos, para descartar esa posibilidad.
What is your exact model as each series is designed differently.
DanJ さんによる
Hp Stream notebook PC 11
Lamin さんによる
Hi @laminkanu
Try plugging in a USB keyboard and check if that works OK.
This is to prove whether the problem is in the laptop keyboard or in the OS.
Has the laptop gotten wet at all i.e. liquid spill on the keyboard?
jayeff さんによる
I have also tried an external USB keyboard. But the Sam problem repeatedly happens.
Secondly I didn't spill liquid on the keyboard.
Lamin さんによる
@laminkanu
jayeff さんによる
