メインコンテンツにスキップ
Airport not being detected
I've tried multiple working airport extreme cards. None are detected. Ran hardware tests card is never detected. Verified that all cables are fine and connected. This is one of the boards that has the ram slot issue. Currently running 10.5.8. It's not detected in 10.4 either.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
It sounds like a logic board problem. Can you find one of the USB wifi units to try? If that corrects the problem you can swap out the card cage which may correct your problem. Ralph
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I tried a PCMCIA card, but not a usb. I'll pick up one and try that. I also posted a question about screen flickering, but I believe both of these were in the hope it was not a logic board issue.
さんによる
If you tried a PCMCIA card and you have the flickering problem I would suspect a logic board problem. Ralph
さんによる
I was hoping that wasn't it. But Logic Board replacement will be my next step. Thanks Ralph.
さんによる
コメントを追加
回答を追加する
stacywebb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 2,010
