Line in won’t work
Line in won’t work with my thing
(Wii av port)
Logan Lamothe follow the instructions in your manual. If you do not have one, you can download it at places like this
You need to check/set the side switch LINE SELECT IN OUT and see if that changes anything. Of course you also have to make sure that your AUX cable is compatible. Double check the manual for all of this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 194
Logan Lamothe your "thing" being a DVP-FX810? Sounds like you are trying to connect a WII to it. Is that correct? What happens when you try?
oldturkey03 さんによる
No picture appears and it still says line in
Logan Lamothe さんによる
