メインコンテンツにスキップ
The Galaxy A12 is a low-end slate Android smartphone released by Samsung in November 2020 as a successor to the Samsung Galaxy A11. Identifiable by model number SM-A125 (followed by version/carrier-specific character.
20回答 すべてを表示
FRONT SCREEN Galaxy A12
Is the screen replacement hard to do on the A12 , front glass only?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Logan Rich front glass only? Not if you have the right tools and plenty of experience. You'd need something like a separator, probably some cutting wires and other miscellaneous hardware. Then you have to clean the AMOLED properly and readhere the glass with the proper adhesive and have it all nicely lined up. So, by the time you have the tools, the cost will be higher than a replacement display assembly. These screens are a PITA to do a glass only repair and getting it done right on the first try is an achievement. I suggest you replace the complete assembly. Not saying it can't be done but a major source of frustration.
Check videos like this to see if you think you could do a complete assembly replacement.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
If you want to replace the entire lcd screen, it is not heavy, but if you want to regenerate the lcd and replace the digitizer without knowledge and tools, you will not get it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Logan Rich さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 3,940
