メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
Repurposing iMac to become a display
Hi,
I'm currently researching on ways to repurpose my iMac to being an external display. Since I would have the speakers, I was wondering if anyone knew an implementation on how to have the speakers connect to this display panel board https://www.aliexpress.com/item/33014928...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Giovanni Morabito the description does not show the board well. Since it has an audio out jack for headphones I would use that with a small pre amp. Easy build and not to costly at all.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
@oldturkey03 any preamp suggestions? and also how could I get the preamp to have power
さんによる
I saw this video https://youtu.be/7HEkJgU0SLA and it seems they used a preamp of https://www.aliexpress.com/item/32790068...
さんによる
@Giovanni Morabito that's what I'd be looking at. You can get the power from the same AC adapter that your are going to use for the driver board. You know it's going to be a fun build.
さんによる
@oldturkey03 any videos to show how to wire from an ac adapter? never really worked with wiring before LOL
さんによる
@Giovanni Morabito not really but go ahead and purchase the driver board etc. Once you get the parts let us know (and see) and we can draw you up some simple diagram.
さんによる
コメントを追加
回答を追加する
Giovanni Morabito さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 219
