Samsung WA52M7750AW Top Loader Buttons Not Working
Hello, hoping someone have direct me on the right path. As the title says, Samsung WA52M7750AW top loader. The washer runs fine, but the select buttons, temp, spin, soil, pre load, extra rinse, etc, don't work. You can't change the selection. Power and start/pause, door lock all seem to work just fine
Would issue be the touch sensor assembly or control board or main board? I'm leaning on the touch sensor assembly?
この質問は役に立ちましたか?
7 件のコメント
Are the buttons that you're talking about regular buttons or touch buttons?
Andrew S さんによる
Thanks Andrew. To me there are touch buttons. Unlike the Power and Start/Pause.
NotDeaf さんによる
@notdeaf I think you may have corrosion or other problems on the circuit board that the touch buttons are on. I would recommend disassembling the washing machine and taking a look at the touch sensor board. If you can't find the fault, you can then upload a picture of both sides of rhe touch sensor circuit board. iFixitでの質問に画像を追加する方法
Andrew S さんによる
Good points. I opened it once. Wasn't too sure on how to remove the board from the display. But checked and rechecked the wires and connections, thinking the same, a bad connection, lose wire. Back together and no change, the issue is still there.
I'll take any pointers on removing it from the display.
NotDeaf さんによる
I have the same issue. I have tried the touch sensor and control boards. washer boot up and seems fine. It does have a 56 in the display. I could not find an explanation of this. All touch buttons and the dial are unresponsive. Child lock indicator is not lit. Any ideas
Jeff Quinton さんによる
2件以上のコメントを表示
