Samsung Chromebook 4 Screen Repair needed
I need someone to help me repair the screen of my samsung chromebook 4.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
Here's a video that shows how to replace the screen in a Chromebook 4.
Search online using the full model number of the laptop to find suppliers of replacement screens e.g. search for "Samsung (insert model number) LCD screen"
Sometimes the screen's make and model number or a part number can be found on the back of the screen itself. Use this information to find a replacement. Of course you will have to remove it first to find out ;-)
If doing this yourself seems too daunting, contact a reputable, professional laptop repair service and ask for a quote.
このアンサーは役に立ちましたか?
got any suggestions of replacement of the whole "lid" and the plastic "bezel" around the "LCD"....?
it took a tumble off the table and the hinge got bent in tje fall it shut the lid in the fall...saved the display but the bezel and possibly the "hinge" got bent up.
when I opened the screen carefully I had.to shimmy it open carefully and tje display did flicker a little bit like a connector may have been bent too
BUT I'm actually using it ATM no problem. other than if I close the lid the hinge kinda "buckles" and I have to kind of support it to get it closed (but the display screen stays lit up now)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 151
