メインコンテンツにスキップ
Repair information for the first generation Toyota Tundra pickup truck (model years 2000-2006)
tail lights stay on when truck is off
why would my rear running lights stay on when the truck is shut off?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @kergan29 ,
Are you sure that it is only the tail lights and not the license plate lights and the front parking lights as well?
Here's an image taken from the 2003 Tundra service manual and it shows that all the above mentioned lights are on the same power feed from the integration relay.
According to this link, Post #5 states "...the integration relay being located in the junction block just below the fuse panel at the lower left dash panel and post #9 states "...the integration relay is actually the circuit board behind the fuses."
It seems that the problem may be in the integration relay circuit for the tail light as the lights should turn off even if the taillight switch is on, with the ignition off and the driver's door is open.
(click on images to enlarge)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kergan Brandt さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 27
今までの合計 1,571
