メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
20回答 すべてを表示
Which direction to pry to remove battery from iPhone 4?
Alright I have followed iFixIt's guide to replace the front assembly on an GSM iPhone 4, but 3 iPhone's I have messed up because of how I removed the battery. The picture on that guide is misleading because it seems like its going the wrong way to pry it. Could someone please instruct me how/which way to pry off the battery from the battery connect, so that it does not break off from the logic board? Thank you so much!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
I put my tool on the side farthest from the battery itself / closest to the left hand side when you're looking down on the phone, just a light lift is all that is needed, obviously, make sure you've removed the screw and that weird little bit of metal that is usually there as well ;) [although I just opened one and it was under the screw, if so, don't worry about removing it until you've un-screwed it]
after that just gently go around the battery from all sides to get it off the glue.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Josh Forester さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 906
