メインコンテンツにスキップ
Nintendo Switchは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
708回答 すべてを表示
Where can I find a replacement for the foam between the heat sink and
I recently replaced the fan for my nintendo switch, and was not able to recover the foam tape that went between the heat sink and the fan due to some exceptionally stubborn adhesive.
Does anyone know of a suitable replacement? The only thing I had on hand was a 0.5 mm thick thermal pad, so I cut that into appropriate sizes and applied it to the heat sink. Is that an absolutely terrible idea? I haven't really tried to put that switch through the ringer to test the thermals, but it's been working fine under light use.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
I found this website that sells foam: https://www.foam-material.com/ I don't know what foam you would need, I would try and find something that looks similar to the foam on your Nintendo switch.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
the carbon fiber looks pretty similar and its properties of it would withstand the heat and possible shock from dropping it.
https://www.foam-material.com/sample-cus...
さんによる
コメントを追加
There is no commercial tape, I've looked everywhere and got nothing. What you'll need to do is get activated granular carbon foam (I have no idea how expensive it is, but I have seen some manufacturers offer free samples that would suffice) and use whatever adhesive you think would work.
I don't know the porosity, but I'm sure a professional would be able to figure it out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Trae Block さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 281
