メインコンテンツにスキップ
Why does the Aria eat batteries? (fixed)
As they get older, a FItbit Aria scale can drain four AA batteries in a week. Batteries should last months. This is apparently a common problem, possibly due to strain gauge sensors becoming flaky over time. Has anyone found a fix?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
I have the same problem to I am guessing because the contacts are touching and draining power.
さんによる
I don't think mine is a contacts problem. If I place the scale in my peripheral vision, the display seems to turn on spontaneously, and then times out and sleeps. It does this dozens of times per hour, which would be the reason for eating batteries. I found several mentions of flaky pressure sensors in the feet, triggering the display. If I could find a source for the sensors, I could replace them to see if it fixes the problem.
さんによる
Clean the scale of dirt buildup. Is your home very humid, possibly triggering the scale turning on? Tried customer support?
さんによる
コメントを追加
1 件の回答
ベストアンサー
With further research, I found that the Aria has a poorly designed activation mechanism in the feet, with a plastic flex part that breaks, causing the activation contacts to randomly short, which keeps turning on the display. This happens repeatedly from any vibration or temperature change, and drains the batteries. The solution is to repair the flex part, possibly with glue or resin, or 3d print the replacement part from thingverse.
このアンサーは役に立ちましたか?
スコア 4
6 件のコメント:
If you can, post a snapshot of a faulty pad switch.
さんによる
Video shows take apart and the flex part that breaks all too easily
https://youtu.be/FeWzibIgPW4
さんによる
I found someone nearby who printed the thingverse part, and successfully replaced the two broken flex parts (that were cracked in multiple places). The scale seems to work fine now and only activates when I step on it.
I can post pictures and details if anyone is interested.
さんによる
Very helpful tip for resolving battery issue.
Thank you.
さんによる
You are welcome. It is quite gratifying to help keep things working, so they don't become waste.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Leonard Cho さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 56
今までの合計 1,799
