メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Currently trying to connect my phone to sanyo FW40D36F B via HDMI cord
Currently trying to mirror my phone screen ( a UMX model U696CL through assurance wireless) to my sanyo tv (model FW40D36F B) and it won't work I'm using a normal HDMI cord and adapter to connect from tv to phone, I know the cord and adapter work. Idk what to do please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @babyalexisxx ,
If you haven't already done so, try enabling Apps > Settings > Connected Devices > Cast and see if that works,
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
That's not on my phone settings
さんによる
@babyalexisxx
Maybe I'm wrong but it is shown in the user manual for a U696CL phone, (see p.47), unless there are two different phones with the same model number.
If there are no "cast" or "mirror" or similar settings anywhere in the Settings, then perhaps your phone doesn't have the capability to do so due to changes to the Android OS by the supplier of the phone i.e. access wireless.
さんによる
@babyalexisxx
Try looking in Settings > System > Backup and look for cast or similar.
If nothing there then Assurance Wireless has installed a custom rom (OS firmware) in the phone for some reason, that does not have the feature.
You may need to get a different make/model phone which has the screencast feature installed. If you decide to do this check the phone's user manual that it does have it and then check the phone itself before you buy to make sure that it is.
Caveat emptor - buyer beware.
さんによる
I have the same phone with the same issues and the guidebook is different from that model that I have must be two different guide books are two different models but I still can't connect or task for my phone I think I might have to buy a new phone
さんによる
コメントを追加
Check your wires make sure they all connected or check to see if they work on another TV if they don't it's your wires that don't work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alexis さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 27
今までの合計 999
