メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
478回答 すべてを表示
black screen, stuck in dfu mode and error 4014, need help pls
Hello, i just bought a iphone 11 from a friend and the screen doesn't turn on, when i try to use itunes it says it's in dfu mode and when i try to repair the phone (with itunes) it says error 4014, i tried different cables, different computers (both pc and mac) and cleaned the lightning port but it did nothing. My friend said that the phone got dropped and never turned on since (the screen is looking perfect and it kinda turns on when i use itunes but it turn off again just after). And yes i tried some "repairs" like tapping around the screen and the back glass, force restart the phone (doesn't do anything to this phone), put it in the freezer for 30 minutes, let it charge for an hour and nothing helped. Pls help me, i don't wanna spend money on reiboot for example if i'm not sure it will work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
An iPhone that boots to DFU mode means there is a faulty component on the logic board. The main components to cause this error are a faulty CPU or NAND. Error 14 usually means the NAND is full or faulty. This will be a costly repair.
 Reiboot or any other software claiming to fix this problem will not work.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks, if i want to try to get a new nand for it, how can i do it (i saw tutorials showing how to replace the nand) but they sometimes say that i need to program it and i didn't understand in
さんによる
@splatlechat To replace the NAND you will at least need:
• Experience in microsoldering.
• Equipment including hot air station, soldering station, solder paste and reballing stencils.
• NAND programmer. You will need to copy the sysconfig file from the old NAND to the new one. If the NAND cannot be read you will need to order a GSX report and manually write it to the NAND.
さんによる
コメントを追加
Actually, cold is the wrong thing. Heat is crucial. Example a notebook, e.g. HP ProBook, which no longer starts. Remove all components, including the batteries, wrap the mainboard in tinfoil and put it in the oven (without circulating air) at 180°C (355°F) for 30 minutes. This not only fixes cold solder joints, but also erases memory contents like the CMOS. Of course, a smartphone is more complex, but maybe this will work. Take one more layer of tinfoil to be on the safe side.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anatole Jan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 29
今までの合計 775
