charging port broken how can I replace it
the pins got bent in the port and no longer charges need to no how to take old port out and put the new one in
この質問は役に立ちましたか?
この質問は役に立ちましたか?
steve watts, the Mini E10i uses a micro usb port. It is soldered on the logic board. In order to change it you will have to solder very small pieces in a very small place. So, if you have not done such thing before, you will need to practice this first. The part is available at places like this. To see how your phone is disassembled, check on the ifixit teardown. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 5,895
