メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
My device won’t power on.
Hi, my ASUS T100TA won’t power on, When plugged in, LED slowly blinks orange/amber.
I hard discharged the battery, removed the tape on the POWER button and plugged it in and… LED still slowly blinks orange/amber.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
NOTE: My laptop/tablet was actually a ASUS Transformer T102HA. But since it didn’t exist it the repair tutorials, I picked the device that was the closest to my computer. Instead of showing a green light, it shows a white one. My computer is 5 years old and 6.6% of my computer’s battery is degraded, which means it can only hold 29 138mWh instead of the rated 31 200mWh. But is 93.4% battery health low? When my battery needs remplacing, maybe I will do a tutorial about how to replace a battery of a T102HA.
さんによる
مرحباً، جهاز asus t100ta الخاص بي لا يعمل، وعند توصيله بالكهرباء، يومض مؤشر led ببطء باللون الأبيض أربع مرات
هل من حل
さんによる
コメントを追加
1 件の回答
ベストアンサー
When the LED is green the battery charge is between 95% and 100% and the AC power is on. The orange/amber LED indicates that the battery power is below 95%, and the AC power is on. Without the charger plugged in an orange/amber blinking shows the battery charge is below 10% and needs a charge.
However, if your laptop battery percentage is above 10% and the LED keeps blinking orange/amber it may mean the battery needs replacing.
Lithium-ion cells age the moment they leave the factory, plus the ~500 cycles they can do (to 80% capacity considered EOL). That means the batteries in the long termed stored laptop will be degraded, even without having been cycled or used.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Oh, also, I found out that I didn’t properly hard discharge the battery. When I left it for a night, the battery was completely dead and when I removed the tape that was holding the POWER button to the on position and I plugged in, this time the light was still orange/amber but was no longer slowly blinking. Now after this, the computer now worked. I will remplace the battery when BatteryBar shows a high percentage of battery degradation.
さんによる
But still, thanks.
さんによる
Update: BatteryBar is showing 84% battery health (I think) but it’s not the worst! My iPad 6th Gen, which I got it on Christmas 2018, has 1931 battery cycles which equals only 61% battery health!!!
さんによる
Hi @steven062010
For a 5 year old computer 84% is pretty good.battery health.
さんによる
It’s because i rarely use it compared to my iPad. I always plug the charger when using it. I switched to a pretty old HP Spectre Pro x360 G2 laptop, it has a mostly brand new battery, since it was never used for some years.
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Steven062010 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 92
今までの合計 8,038
