メインコンテンツにスキップ
Released in 2016, the Samsung Galaxy Tab A6 is a mid-range tablet designed to take after the Samsung Galaxy A series phones.
Can the version of android be updated
Tablet is running version 5.1.1 - can it be upgraded?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
2件の回答
最も参考になった回答
It can run up to Android 8.1
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Thanks guardian10.
I went to settings - about device - software update and it downloaded an update and installed it and optimized apps. But, when I look at about device it still shows version 5.1.1.
I restarted the tablet and it still shows version 5.1.1.
I tried software update again but it says it is up to date.
Any ideas?
Thanks
さんによる
@rick fredricksen That is very odd. I do not know anything beyond that. I have not worked on Android tablets before. I mostly work with Apple products. Are you sure it is a Galaxy Tab A6?
さんによる
yes it is a Galaxy Tab A6
さんによる
Try updating again, if that moves you up try again until it doesn't say an update is available. OTA updates tend to go a step at a time not all in one great leap... yes it s weird.
さんによる
I have the same tablet; mine was updated a while ago to ANDROID 8.1.0
Jan Broenink
さんによる
2件以上のコメントを表示
コメントを追加
The Samsumg Tab 6A has a small porblem If you have the SM-T280 it cannot be updated or even rooted. Check your model number.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
That is unfortunate. I have that nasty SM-T280 :-( Thanks fro the heads up because I have been trying to wrestle an update for some time. Have a great day.
さんによる
As noted before, The Samsumg Tab 6A has a small porblem If you have the SM-T280 it cannot be updated or even rooted. Check your model number.
さんによる
You're wrong. There is a version of supersu for it, and a version of TWRP, Lineage OS and E OS. All are built by the community, and have barely any bugs. Updatable up to android 7.1.1, or 8.1 if you find a custom rom for it.
さんによる
コメントを追加
回答を追加する
rick fredricksen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 76
今までの合計 7,147
