メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年10月にGoogleより発売されたPixel 第三世代モデルです。
Pixel 3 won't charge; suggestions for booting/retrieving data?
Hi,
I have a Pixel 3 that no longer charges and has run out of batteries. I noticed shortly before it did that it was at 1% battery. When I plugged it in (or used the wireless charger), the charging symbol turned on and it stayed powered indefinitely, but the % charge never went up. I should have copied my data off—only one thing I need—but instead I attempted to reboot. It powered down and now won't turn on, display anything, or charge.
Any suggestions on how I might get it to power up long enough to copy some data off?
I've removed the back and wireless charging coil successfully, but have stopped there. I honestly don't care if the device ever charges again or survives the process overall, but I also don't really have any ideas on what to do from here.
Thanks for any help!
-Jef
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント
Can you try to safely take out the battery (without destroying it)?
さんによる
@andrewsawesome I think I can. I've disconnected it, though, and that had no effect; are you thinking of getting a pre-charged battery and trying to boot off that? Or something else?
さんによる
@puk
Just verifying that there are no previous backups in the cloud that you could use?
さんによる
@puk I was thinking of soldering a power supply to the terminals on the BMS board, but a pre-charged battery would probably be easier.
さんによる
@jayeff That's correct. (It's unfortunately not really eligible for cloud backup except manually, which is why I should have done that before I powered down.)
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
@puk Generally, a phone will not power up unless a good battery is connected. If the battery really doesn't hold any charge, the symptoms you are describing would make sense, so I would recommend getting a new battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jef Pearlman さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 29
今までの合計 233
