メインコンテンツにスキップ
HPのOfficejetはインクジェット用プリンターのシリーズです。
357回答 すべてを表示
HP 8610: One or more cartridges appear to be damage!
Hi, I turn it on, it complains about a damaged cartridge, so I open the front door to replace.
When I open the door, the carriage does NOT move, and the error message now says to close the door to print.
I close the door, and the original damaged cartridge error message returns.
I read some article that says you should downgrade you r firmware and I tried to go service menu by 4 taps on back icon on left side of screen, but I can't get to any service menu, and I have tried unplugging, waiting and plugging back in, and I have tried forcefully moving the cartridge, but nothing works.
Anyone has any experience about this error?
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
well, have you tried replacing the cartridge?
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Yes, is there any way that I access to service menu when my printer has error?
さんによる
let me check
さんによる
if you open it then you can see a wire connecting to the cartridge , check that wire to see if its damaged
さんによる
if that's not damaged then try to look at the connector between the cartridge and the connecter
the place where you place the cartridge
さんによる
and finally yes, you can access to service menu when your printer has an error on these steps:
With the printer turned on, disconnect the power cord from the printer.
Unplug the power cord from the power source.
Wait 60 seconds.
Reconnect the power cord to a wall outlet and the printer.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
megan D さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 28
今までの合計 1,213
