メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
48回答 すべてを表示
VCR/DVDr combo player turns off when there is no light
So I'm looking at a parent's Magnavox zv420mw8 VCR/DVDr combo machine which hasn't worked properly in years by just powering off after a couple seconds of powering on. What I've discovered after playing with it is the DVD portion anyway will run correctly as long as the top of the player is removed and receiving light. If you make the room dark or cover the top with the machine with its cover it'll power itself off because of something in the VCR section. Anyone heard of sensors causing this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
I actually solved the issue and half fixed the unit. There was a clear plastic pillar piece that was broken on the VCR side that sat over a tiny bulb hidden underneath it. Replacing that piece allowed the unit to keep running with power and the DVD side functions normally now. VCR side remains dead, but she just wanted to be able to finalize her DVDs.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shukuun さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 30
