メインコンテンツにスキップ
The Roberts nailer model 10-600 is a 20-gauge electric stapler with a carrying case that is designed for carpet installation projects.
1回答 すべてを表示
Staple plunger will not retract
My new Roberts 10-600 stapler failed on the second day of use. I am installing a vapor/ insulation barrier in my garage and using this stapler for the job of attaching the barrier onto the 2X4's. I shot approximately1000 staples and now the plunger that drives the staple into the wood will not retract.. You can manually drive the plunger back into the housing and it will fire one staple and stick again, It has been properly oiled after the initial use and now, the second day it worked for about 15 minutes and failed. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Since it is new it will be covered by the manufacturer's 12 month warranty
Follow the directions in the warranty form to make a claim for a warranty repair or replacement. Do not try to fix it yourself as doing so will void the warranty.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joe Kolger さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 10
今までの合計 171
