I dropped my phone and the screen is cracked.
I dropped my phone and the screen is cracked. The display is turning on for like 0.5 seconds at a time and then turning black. How can I fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You'll need to get the screen replaced. Check around local independent repair shops and get quotes. You can also fix it yourself if you're really comfortable with it
このアンサーは役に立ちましたか?
my phone is cracked and broken
I can not call or text anyone
Mezdari, assuming you're on topic here and you're referring to replacing the screen on a Samsung Galaxy A02s, then this guide should work to step you through the process of repairing your phone.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 11
過去 30 日: 58
今までの合計 1,750
6 件のコメント
Haw i fixes my screen phone
Mezdari Youssef さんによる
Never drop my phone 📱
elohor Okor さんによる
شرخ في الباغه
طريقه التصليح
Zezo King さんによる
Basically I dropped my phone by accident and the left button of my phone is cracked and the screen is not working
Emerick Ambella さんによる
@emerickambella As far as the screen not working, it's almost certain that it broke when it was dropped and needs to be replaced. See my answer below for a guide showing you how to do that.
As far as the "left button is cracked" problem, you'll have to elaborate on that. According to Samsung your phone doesn't have any buttons on the left side of the phone; all three - power and volume up/down - are on the right side, so it's not clear what button you're talking about.
Your best bet for getting help is to start a new question and add pictures of the damage.
Jerry Wheeler さんによる
1以上のコメントを表示
