メインコンテンツにスキップ
Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
16回答 すべてを表示
Why are my rear tires locked all of a sudden?
I'm having the same problem if anyone can answer.. I have a bad wheel barring and the back all of a sudden locked up and you can hear the gears griding when you try and move it.. my mom's boyfriend said I need a new rear end.. is there anything else it could be where I didn't have to buy an entire rear end?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Sorry this isn't the answer but a comment.
I remember from somewhere that the 4Runner has a senser that will normaly engage the locks if the car is in need of extra traction.
If this is so, you might want to look into fix/replacing the senser unit/controller. But first try ungluging the wires to the RR lock switch as this might be faulty.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ashley Dickinson さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 71
