1- is 1F115-005-7 correct replacement battery
2- need USB for 4S to connect to my Dell Insprion 15 /3000 , is 1F182-012-1 the correct USB? (((((((((((((WHAT DO I NEED TO CONNECT MY iPHONE4S TO MY DELL INSPIRON 15/3000 COMPUTER))))))))))))
To connect an iPhone to a pc you need to use an 30 pin cable.
Here is an cable from appple . If you'r pc or laptop dosent have an USB port you can find adaptors really cheap on Amazon.
Hope that helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 40
Do you have iTunes installed on your Dell Inspiron 15 3000?
Andrew S さんによる
