メインコンテンツにスキップ
Failed hd (and fan?)
Just dug an old PowerBook G4 out of the attic. It booted up fine, though I had to hold Option down in order to manually select the boot volume--which I attributed to years of being without power and the PRAM losing settings.
After a few minutes it made a buzzing sound, and I vaguely recalled it doing so before I'd retired it; I'd attributed this to the fan at the time. It was annoying so I shut it down. But when I rebooted the next day it started making a loud and HORRIBLE sound. This: https://youtu.be/qXl_EyPpGHo
Again, be forewarned: loud and horrible. It's not as if I have experience in all computer failure sounds, but I think the hard drive is riding its platter, and it suddenly won’t boot anymore.
I’m debating replacing the drive. I know it’s involved but I have the tools, have messed around in PowerBook innards before, and it’s not as if it’s valuable anymore.
Two questions:
— it uses an ATA drive; any compatibility reasons I can’t install a more readily available SATA?
— is it possible there’s *also* a fan issue, or could the noise have all along been a failing drive? Unfortunately I don’t have a recording of the old sound, but is the above sound, starting at 0:13, a fan noise? If so, would the fan need compressed air or replacement? The only fan I could find that was clearly marked as a direct replacement would be as much as a new HD.
FWIW, back in 2008 I was traveling with the PowerBook, and a flight attendant said I had to put it in the overhead rack (I didn’t have a seat in front of me and she said it couldn’t be on the floor during takeoff). She put it in, and when I went to retrieve the bag it hadn’t been put in properly and fall 6+ feet to the floor. The case warped a bit; I wonder if this problem stemmed from that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
To be safe, replace hard drive and have a fan if it’s the problem.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
OK, but my question wasn't whether I should replace the drive, but whether SATA would work or if I need to stick with ATA. And I won't know if it's also the fan unless I put everything back together and it still makes the noise, which means I'd have to take the whole thing apart again.
さんによる
@scott_ar You need ATA.
さんによる
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 104
