メインコンテンツにスキップ
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
How to reset the anti theft system
How to reset your anti theft system in a 2001 Grand jeep Cherokee Laredo
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
6 件のコメント
Did you review previous questions with answers related to your Grand Cherokee, the box on the right?
さんによる
Mine wont start at all. Battery ok. It's 2021 Jeep Rubicon. Cant shift out of park etc
さんによる
This did not work on my 2002 jeep liberty sport.
さんによる
This doesn’t work on 08 Wranglers
さんによる
Didn't work on my 2004 jeep grand cherokee
さんによる
1以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Step 1
Enter your Jeep and press the Lock button on your keyless remote five times in 10 seconds.
Step 2
Insert your key into the car's ignition, turn it to the "Run" position and wait for the car's chimes to stop.
Step 3
Press and hold the "Unlock" button on your remote, and then press and hold the "Panic" button while still holding "Unlock." Hold both buttons together for one second and release.
Step 4
Wait for a chime to sound and press and release the "Lock" and "Unlock" buttons on your remote.
Press and release the "Lock" button by itself and wait for the car's chimes to sound again to indicate successful resetting. Remove the key from the ignition when you are done to finish the procedure.
このアンサーは役に立ちましたか?
スコア 5
17 件のコメント:
Will this work if the jeep stopped recognizing the key?
さんによる
which button is the"panic
' button?
さんによる
I tried the above procedure it does not work is there any other options
さんによる
it did not work on my 2005 Jeep Liberty nothing works on it I've tried every thing out there somebody help!!
さんによる
12件以上のコメントを表示
コメントを追加
2004 jeep grand Cherokee laredo don't have key fobs. How do I disable it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Replaced pcm programmed to ignore disabled/ removed skim in 99 grand cherokee. It now runs with any key cut to fit. Alarm still flashes exterior lights. Don't have key fob anymore but want to disable Alarm now. Ideas?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MEGAN Jewell さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 48
過去 30 日: 218
今までの合計 65,005
