After getting insider build ran into a problem and reboot and select
So last night I was watching YouTube and suddenly my pc crashed and a green screen appears saying "insider build ran into" it was stuck at 0% for like 5-10 minutes so I decided to restart my pc, after doing that the only thing my pc shows is "reboot and select proper boot device" so I googled and found out that I should open bios and select SSD [m.2] for booting but the problem is my SSD is not showing there, I tried removing my SSD and plug-in it in again but that didn't change anything.
Did it kill my SSD or SSD slot? I need help real quick. ;')
この質問は役に立ちましたか?
5 件のコメント
I had this problem and you just have to change it to legacy boot.
NR26 さんによる
@nytryder26 how do you do that? And it seems that either my SSD or or my SSD slot is unresponsive because it used to light up
Ayon さんによる
https://youtu.be/X-dOgnToOyc
NR26 さんによる
Or the drive is possibly dead.
NR26 さんによる
If the ssd is not detected in the UEFI, changing from UEFI to legacy will not make a difference because the formatting of the ssd will not make make it disappear from the device list.@ayon22 @nytryder26
Duck さんによる
