メインコンテンツにスキップ
Why is my Disk Drive not working?
Hi, I tried to put a PS4 Pro Disk Drive into another PS4 Pro, to see if it works. After seeing it does not work, i put the Disk Drive back into the original console. Now the Disk Drive doesn`t work there either. Everything was working before.
Motherboard and Daughterboard are back together, it should work.
Did I mess it up?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
The best thing that you can do to troubleshoot is to go back through step by step and make sure that everything is connected/seated correctly. My guess is that since it did not work on either console, maybe the ribbon cable has become unseated on the drive itself.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nils Schmid さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 115
