microphone needs to be replaced
where in the bold9700 is the microphone situated, i have the tools to open the phone but not sure where and how to replace the part.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Brian, it's on the bottom right of your logic board. When you disassemble your phone, it should be under a black rubber stopper looking thing. I attached the images to clarify. Here is the teardown to give you an idea how to get to it. Hope this helps, good luck.
このアンサーは役に立ちましたか?
evening oldturkey03-under the rubber stopper the microphone is encased in a metal cover
I think the metal casing is part of your microphone :-)
Thanks i'll try that
Alright, good luck and let us know.
cant get into the casing under the rubber stopper its sealed?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 3,083
