メインコンテンツにスキップ
8th generation of Chevrolet's full sized SUV, based on the GM GT400 platform.
18回答 すべてを表示
Break lights won’t work
So I just got a 98 suburban and my brake lights do not work I replace the brake switch replaced the tail light assembly I have blinkers I have running lights and I have reverse lights.. the only thing I know from what I looked up is the location for the break lamp relay is not there ( no prongs to plug into) truck looks like it has been worked on by a back yard mechanic unfortunately.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Josh Murdick Check for power on the switch (orange wire should have power). There should be a connector under the dash above the steering column (`6-8 wire connector). Check to make sure that it is not corroded and that all the wires are still properly connected. Of course, you did check all the fuses as well as the bulbs to make sure they are of the right type….
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Josh Murdick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 193
