Rear Camera Lens Replacement
I would like to know all of the parts and tools needed to replace busted rear camera lens (the middle lens) and if possible, step by step instructions as well. Thank you
you need isopropyl alcohol, heat source, and a pry tool. you buy an entire new back cover on ebay for $15, pry up the old one with heat and alcohol, clean the adhesive that’s left on the phone, and adhere the new one down. no idea what your experience with repair is, but for a first time or novice repair this would be the absolute easiest method.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 25
今までの合計 443
