water leaking, not from supply or drian lines
So it seems to be leaking during the spin cycle, it is not coming from the supply or drain lines, where else should we look ?
Hi,
Does it also leak when draining the tub between the wash and rinse cycle?
Maybe check if the hose clamps on the pump hoses are tight, that the hose is not split or that the pump itself is not leaking.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 37
