メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年3月発売。モデル番号 SM-A305FZRFINS で識別。
Phone vibrates and shows sign of life but shows blank screen
My phone's screen has been blank and doesn't show anything. I've tried doing a soft reset (volume down + power button) and got it to vibrate showing that it's restarting but it still doesn't show the Samsung logo or the home screen. I've even connected it to my computer and was able to see it as a MTP device, and when I did a soft reset of it while it was connected, my computer played the USB disconnect sound and then the USB connect sound showing it is still alive. Is there anything else that can be done to get rid of this "black screen of death" or whatever it is ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 18
13 件のコメント
Did your display have any other problems before this happened? Have you dropped the phone in liquid in the past 6 months? Has this problem happened after a fall or other damage to the phone?
さんによる
@andrewsawesome No it just stopped working at one point.
さんによる
same here, now u mail to headquarter support.india@samsung.com
さんによる
my phone kept refusing to charge and it would work after you hit off something but this time it cracked on the inside screen and i donno why but it wont turn on but it vibrates when i hold the turn down and power button. i think it cracked and it the mother bored im not sure how to fix this issue
さんによる
@colemcinnes It sounds like you may have two problems now where you just had one before. To fix the charging issue (assuming you've already tried a different charger and cord), you'll probably need to replace the charging port.
https://www.sosav.fr/guides/mobiles/sams...
Now that you've broken the screen, you'll need to replace that too.
さんによる
8件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
@danielife4 I wonder if your "black screen of death" is not a broken display. Just to check this, Power-on the phone and check the power-on sound or motor Vibration. Sound or Vibration is ok? If the answer is yes, replace the display assembly.
If it is not, you will have to check the video circuitry on your PCB’s according to this flow-sheet
画像
Here is the board view Samsung A30 Boardview. Use the search function of the PDF reader you are using, to find the components etc.
I still think your display is the prime suspect ;-)
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
yeah. The vibration works., but there's no way to check the sound since it doesn't have a sound on/off button I can switch. But I conclude at this point that it display assembly is dead.
Does iFix happen to have a tutorial and a kit I could get to replace the display assembly?
さんによる
How did you come across this board preview and guide, where do I find this for other devices?
さんによる
@mohd2126 always check the better forums since a lot of those come from there.
さんによる
@oldturkey03 And where do I find those "better forums" I'm a trained amateur trying to become a trained professional, they did not show me where to find any of these schematics in my training. And your help is very much appreciated.
さんによる
@mohd2126 what specifically are you looking for? ;-)
さんによる
4件以上のコメントを表示
コメントを追加
Facing the same problem 2 days back. As i came to know most of the time this problem happens because of hardware problems like your battery issue or because of water damage. In my case i was facing the similar problem in my samsung s21 smartphone and i was in a bad mood. I searched a lot and found a solution https://okadtech.com/samsung-s21-black-s...
In my case i was lucky it was a software crash and i successfully solved this problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I personally have an iPhone 14, and I woke to a black screen but the phone itself still vibrated. Tapping around, I could figure that it was on and was responding to my taps; for example, I could tell I was at my locked home page when I felt the phone vibrate in response to, what must have been, me attempting to enter a password. So, I powered off the iPhone by holding down the power button and the upper-volume button, then swiped right at the top of the screen just as I would normally, even though I couldn't actually see anything. I could tell my phone powered off bc there were no more vibrations. Then, I powered it back on holding both the power and the increased volume. It eventually showed the apple logo and brought my phone's display back. So odd.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 28
過去 7 日: 186
過去 30 日: 817
今までの合計 74,251
