メインコンテンツにスキップ
2018年11月にiPad Proラインに加えられました。モデルナンバーはA1980です。
63回答 すべてを表示
iPad unavailable, I’m locked out
I just want to restart my iPad by erasing it. It’s currently on airplane mode so I can’t restart it remotely. I can not erase it from iTunes either because the computer isn’t recognizing the iPad. I’ve also tried the power + volume shut down that does not work either. The port will charge the iPad though. What gives and help please.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Hi
I had a similar issue with a iPod touch 6
This video shows you step by step how to basically force the iPad to restart and erase
https://youtu.be/9CHHCDexyHE
Hopefully this will help
Any questions please ask
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Well I tried taking to Apple because I do not have computer they said it has a bad port but it still charges with no problem. I did try the restore but that did not work either. My iPad Pro 11 is a Wi-Fi edition and it’s stuck on airplane mode. I did not put it on that but when you fly it automatically goes to that.
さんによる
Having the same exact issue. Do you think it’s the USBC port that needs to be replaced?
さんによる
@lg2
Hi
Sorry about the very delayed reply,I didn’t get a notification saying you had commented
It could be worth taking it to a repair shop the specialises in board repair to see if it’s a board level issue in any was because like you said if it charges fine the chances of it being a bad port are quite low
さんによる
@chisss
Like I said in the comments above it could be a port issue but if it charges that is unlikely
Your best buy is to take it to a specialist repair shop to see what they can do with it:-)
さんによる
コメントを追加
回答を追加する
lg2 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 74
今までの合計 2,270
