メインコンテンツにスキップ
The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
Network keeps dropping but phone is supposedly unlocked
Hi, I bought an AT&T unlocked V60 and have been using it here in the Philippines for 42 days without any problems but today it refuses to connect properly to my carrier network (SMART Cellular). I've made a Reddit post with recordings about it. I would really greatly appreciate any help resolving this issue.
Things I've tried:
  • factory reset twice
  • switched to 3 different sim cards
  • tried to add new apn (but it isn't saving) Note: I booted into safe mode and added an apn and i got the phone to recognize the carrier, got my brother to successfully call the phone for about 2 mins until i restarted back into normal mode and had the problem again.
Unable to post links here so this is a shortned url: shorturl.at/cgzM2
Note: 2g/3g/4g/4g+ was working fine before today. there seems to be nothing going on with the carrier since my brother isnt having any issues with his phone (ROG 2- same carrier)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
SMART Cellular may have 5 APNs for LG V60 ThinQs in the Philippines. Click the link below to view the list:
https://apn.how/philippines/smart/lg/166...
Do any of these APNs work?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi @dancomptia , so yes these do work but they dont hold for longer than 1 second as seen in the other recordings I added on the Reddit post. I did some digging yesterday and have observed that something seems to be interfering with the Cellular Radio keeping it from always staying on. So I downloaded an app from F-Droid called Tower Collector and this has somewhat fixed the issue, albeit just a band-aid solution at the cost of battery performance.
Do you think this could be a hardware issue ? Or software ? Coz I want to get to get this properly resolved and not rely on band-aid solutions. Also, do you know of any app like Tower Collector that forces the Cell Radio to "always awake" but lightweight? Thanks for answering to my post by the way.
Edit: I've added a log of my network test below. Note that around 7AM~ish was when I started the monitor logger without turning on Tower Collector.
https://docs.google.com/spreadsheets/d/1...
さんによる
Tower Collector seems to detect towers, but I would be skeptical about any third-party app that claims to restore phone connectivity.
If your cell radio can't stay awake, try a factory reset. If it still doesn't work, it may be hardware-related.
If all else fails, I would call the carrier so they can troubleshoot from their end.
さんによる
コメントを追加
I noticed in Android 14 there is a setting in battery optimizer that offers to drop from 5g to 4g to extend battery charge. If you can turn that off, it could improve stability.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Von Ezer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 949
