メインコンテンツにスキップ
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
44回答 すべてを表示
Replaced battery Now it wont turn on
So I have samsung galaxy tab A7 the battery was bad in it so I replced the battery and I messed up the screen A little bit but not bad so waiting on a new screen but it will not turn on I made sure everything was put back together correctly and everything any help??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Jesse Wallz if you are certain you checked and double checked everything you have put back together, follow the instructions from Samsung and see what you get.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jesse Wallzs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 290
